Neil Blanchard wrote:Can the Symbol Browser show us both DSF's and SM3's at the same time? So, if there are two versions of the same symbol, we can delete one.
Unless your using v.11 or older for some reason why do you have SM3's around still? I would see if I could get Datacad to verify that the ini line
[SymbolBrowser]
ConvSM3ToDSF=Truewon't over write any existing DSF symbols, (I don't recall) backup your symbol folders to be safe, set the ini line to True and go to town browsing your symbol folders to get things undated to DSF files. Then preform a search in your symbol locations for SM3 files and delete them.
Neil Blanchard wrote:Also, in the Save Symbol dialog, it would be great to see "All Supported Files" all the time.
Not sure if your asking to be able to save symbols back to SM3 files or not here, but no way should v17 save symbols down to SM3 files
