It's good to see the latest update now has the ability to reassociate 'lost' doors/windows etc. back into smart walls....an improvement that will further streamline this process:
1. The current Re-associate appears limited to a single wall at a time to reassociate 'lost' doors/windows. This will be laborious and time consuming selecting a wall then looking for the correct door/window which fits back to the location, then repeating for all other doors/windows. This probably works okay with smaller floor plans but will likely lead to errors/trial and error with large plans having a lot of doors and windows. Doors/windows that have loosened from walls aren't always seen straight away and it can be a day or more later after hours of further work that these are found.
2. The preferred method would be to have the smart walls automatically/dynamically/real-time re-associate the 'lost' doors/windows whenever a wall is moved, stretched, rotated, mirrored etc. as the inserted doors/windows should remain in the walls given they have been placed there by the user....I don't understand why there is a need to manually reinsert every door/window individually each time, (the 'smart' entities need to be smarter than they currently are),
3. Another option could be that doors/windows automatically reassociate to their component walls after a regen is executed. Not as good as #2 above, but better than the current option,
4. If this isn't possible at present, then add the ability to select the whole drawing (Area/fence/selset etc.), followed by Area/fence/selset etc. of all doors/windows to eliminate the need to individually select one door/window and wall at a time. Offices need to work efficiently to keep up with time lines so all enhancements need to offer the most efficient way of doing something to minimize the time it takes....#2 above would be ideal
DataCAD user since v4!
Regards
Mark Bell
Principal
ATELIER MARK BELL
Australia
Regards
Mark Bell
Principal
ATELIER MARK BELL
Australia
