#80392 by Mark Bell
Thu Nov 11, 2021 6:33 pm
There are a number of occasions where the drawing has walls or entities at angles other than horizontal or vertical. Using B-Tangents to align the crosshair to the wall angle allows easy working at these different angles, but, when using Rotate there's no really quick method to rotate a selected entity to match the crosshair alignment in a single mouse click.
Wishlist - Add S8 Match Crosshair to the main menu so the sequence would be: Rotate / click center of rotation / S8 Match Crosshair to rotate whats selected to align with the crosshair. A further option could be to select the entity again to rotate 90' which allows it to be orientated correctly if further adjustment is needed.
The same S8 Match Crosshair could also be added to the submenu in Dynamic allowing quick alignment if using that function.
