When creating/editing PARATEXT it's quick when after editing the text you can hit the TAB key (which highlights the OK button) then hit Enter to exit the dialog, all without touching the mouse.
MTEXT does not work the same way. A very minor issue...
The current Tab Order puts the highlight on the text size and there is no way to get to the OK button using the TAB key.
Can we have MTEXT dialog work the same way (for consistency) to have the Tab Order include and go to the OK button like it works in PARATEXT?
joshhuggins likes this
DataCAD MTEXT dialog.jpg (25.15 KiB) Viewed 4991 times
DataCAD 22.02.14.02 BETA on my own build Gigabyte MOBO rack mounted Windows 10 Pro 22H2 x64 i7 920
