Re: 1. saving mult pages as single pdf, 2. drawing on jpg
Posted: Sat Aug 30, 2014 8:20 pm
tomarch3 wrote:Regarding Dcad 11:
1) I am pretty new at emailing my drawings. I save each page as a pdf.
But a client recently asked me to put them all into one pdf.
I had to assemble the pdfs in other software. Can Dcad 11 save
several pages in one pdf?
No. PDFill has a merge facility. Maybe that is what you are using
And
2) I imported a jpg of the surveyor's site plan - very impressive -
Can't Dcad let you draw on a jpg?
You can draw over a bitmap. You may find pressing U or ESC will fix this by refresh The layer order can be changed in the display menu. Note also that you can tick the "print bitmap and fills first" item in the pen table - which trumps everything. You can also turn bitmaps off while drawing.
Getting a JPG from a surveyor seems a pretty slack-arsed way to go anyway, and he must have been wondering what that was all about. You might try asking for a DWG file, which will allow you to work in a proper and professional manner, something you should find very impressive indeed, and will absolve you from any bitmap angst as well.
Bitmaps have cosmetic value, but that is all.
