I am trying to insert a bitmap. I have the file in both jpg and tiff (converted from pdf) but when I go to insert it it doesn't insert on my drawing. Lois W
Joined
Thu Mar 29, 2012 4:52 pm
Are you able to insert any other BMP or JPG? If not can you give detailed steps on how you are doing this? Is the targeted layer locked? Do you have display bitmaps toggled on?
DataCAD 22.02.14.02 BETA on my own build Gigabyte MOBO rack mounted Windows 10 Pro 22H2 x64 i7 920
Joined
Mon Feb 14, 2005 8:03 am
Location
Nashville, Tennessee
May be try inserting the images at their lowest resolution/DPI settings first, then adjust their resolution higher until you reach the limit available?
Joined
Sun Feb 13, 2005 1:09 pm
Location
Sunshine Coast, QLD + Darwin, NT | Australia
Users browsing this forum: No registered users and 61 guests
