#79286 by joeferguson
Wed Jan 20, 2021 3:46 pm
This is the shape I couldn't fill properly
(22.23 KiB) Downloaded 328 times
Happy New Year everyone!
I have wondered about this one for years and finally decided to ask the forum.
When doing an spb fill on a shape that contains a small radius arc, I often, but not always am not able to execute the fill. By small, I am talking about less than 1/64". The program simply doesn't perform a fill using Contour Search.
I try to cheat the program by creating a polyline and then filling the entity, but DataCAD returns a similar but not exact shape, where the small radius arc is returned as a straight line instead of an arc.
NEWS FLASH!
By taking the time to write out this challenge, and examining my post to see if I had properly described the issue, I decided to try changing the accuracy in Settings. I changed to 1/256 and bingo! my shape was drawn accurately.
So this forum is helpful sometimes even before I post my question.
Thanks again for being there. I thought I should post this in case someone else might benefit from it.
joe
#79302 by joeferguson
Fri Jan 22, 2021 10:05 pm
UPDATE
Changing accuracy in Settings does not work in more complex cases (with several curves of small radius).
However, I found another workaround: If I Enlarge the shape by a large factor, DataCAD will allow me to convert the lines into a polyline, then I can SPB fill the entity, then I need to shrink the entity by the inverse factor of my enlargement. The curves are returned accurately.
Takes quite a few extra keystrokes. Is there a more elegant way within DataCAD to achieve the same result?
joe
