#80672 by Gary24752
Wed Feb 23, 2022 2:04 am
How do you go about setting the default distance for both "z" base and height. I know how to change it but there must be a way of setting it to begin with. I am assuming once that can be set can this be used to figure volumn and if so how or what do you have to do to get that?
#80674 by Roger D
Wed Feb 23, 2022 9:02 am
z
hit the z key, set the z-base, z-height and those settings will continue to be used.
Caution, if you do a Identify, set all, then the z values will be changed to what that entity z's are
#80676 by joshhuggins
Wed Feb 23, 2022 11:50 am
Also, if you create and use base files that have your typical drawing info like borders, typical notes, typical details, etc., you can set your z-base/height in those file to a default value as well so your new projects always start how you prefer.
