#82578 by cadline
Fri Nov 17, 2023 9:14 am
How do I switch off this Macro Hint bar?
#82579 by Roger D
Fri Nov 17, 2023 9:38 am
are you using a macro?
I turned on every toolbar in the list and tried to mirror and nothing like that showed up.
reboot and try again?
#82580 by cadline
Fri Nov 17, 2023 10:53 am
I had to install the latest Beta version and now this appears when I select the Mirror menu
#82581 by dhs
Fri Nov 17, 2023 12:47 pm
I have never seen this Toolbar, and I am not getting it when I go to Mirror menu in latest version, but you could try checking the Disable Macro Hint Toolbar option in Program Preferences. This option exists in previous versions, and I don't have it checked (even though I am not seeing the toolbar), but hopefully it will fix your problem ...
#82582 by Roger D
Fri Nov 17, 2023 1:59 pm
what version are you on, I'm using ver 22.02.15.06(SE) and can not see it and like Dave (dhs) it's unchecked in Prog Pref and I still don't see it.
Looked in the .ini file and it shows as
Suppress Macro Hint Toolbar=False
I even turned it on to see if it worked in reverse logic, didn't see it.
#82583 by cadline
Sat Nov 18, 2023 12:04 am
Thank you, Dave,
For some unknown reason, I missed reading this function
By selecting it, the function switched off after restarting the program.
Have a great weekend and Regards,
Users browsing this forum: No registered users and 140 guests
