Do you believe that Global Climate Change is real, and that it is caused by humans?
If you do not believe in the Theory of Gravity, will you float away?
All the braking should be engaged by the brake pedal; pure and simple. On an EV, all the regenerative braking should be used to regain as much of the energy as possible -- but this is less efficient than coasting, by definition; so it should not be the way you drive to maximize range on an EV. So, as much braking as possible should come from regeneration
Users browsing this forum: No registered users and 71 guests
