My "Scale Type" keeps changing from mm to meters. I'm not sure what key strokes I'm using to induce this but I think it's related to either identify set all or editing PText. I'll keep working and try to spot when it changes.
Also, identify set all on an existing dimension causes the dimensions to display in meters despite the scale type being mm. "U" refreshes them back to mm
Just noticed that identifying hatch and fills will cause the scale type to change
Lincoln UK
DataCAD 16
DataCAD 16
