There's a bit of a problem. Now when I shutdown and reboot with the Hardlock Key in the USB port, the computer HANGS UP!. I have to hard shutdown using the button. Then REMOVE the USB KEY, and reboot.
Then I can put in the USB Key and use DataCAD.
SO, I guess for now, the rule is:
LEAVE THE DATACAD USB HARDLOCK KEY out until you have fully booted!!!
THEN plug it in.
I am now wondering if the USB driver should be put into Win XP compatibility mode or perhaps we need a different driver.
If anyone knows more about this I would appreciated a response with the details.
Also DataCAD x3 seems to be working in native Windows 7 x64 without having Windows XP compatibility set to run, Is this correct?
Thanks
Rick
Rick,
You need to email Tech Support and ask them for the hardlock DLL file. The 64bit version of Win7 "protects" you from the Installer, for some reason. Once you get the DLL, you need to manually copy it in the Windows subfolder -- Mark will tell you the name of it.
I had to do this last week at a client's office, and if you need it before Tech Support can get it to you, I will try to get him to forward me the file; and I'll forward it on to you.
Hmmm, I didn't have this issue but maybe it's because I always disable UAC after I install windows? But now that I think about it my co-workers systems with Win7 64 bit who do have UAC on didn't either. Might be worth a shot and try shutting off UAC. Click Start, type UAC, and select Change User Account Control Settings, drag the slider to the bottom & reboot), install Datacad to the C:\ and then re-enable UAC. UAC is a handy feature to leave on as it will help stop some of the sneaky stuff out there.
Thanks! - Josh
Josh's Digital Downloads is come back online soon. Stay tuned.
I'm with Josh on this - I didn't have any problems when I installed X3 on my new Win7 box. I also disabled the UAC - I can't stand it! At least Win7 allows me to turn it off and not remind me every time I turn the computer (like Vista does)!
Highest Regards,
Alan T. Hendry, RA
Alan T. Hendry, RA
I just had to format and reinstall with a replacement disk of W7Pro/64 with SP1. Prior to this X3 was working fine, now there is NOTHING I can finagle that will make this read the hardlock. I have done everything listed above and even copied the DLL file to anyplace that I thought it might read it, yet it keeps telling me that I have an "Unknown Hardlock Error". when I unplug the USB dongle and plug it back in it gives me a failure. See attached. I have the UAC turned off, I've unistalled/reinstalled/deleted the driver software/reinstalled and it still keeps coming back with this? HELP.
May all your dimensions be the sum of their total.
Not the best advice, but wait for V13.06 and the Softlock key?
Until then ... a few "no-brainer" suggestions (forgive me if you've tried them):
- Make sure you are logged in with a User Account that has Administrator rights
- Make sure that DC is installed under the root directory ... NOT the /Program Files/ subdirectory
- Try plugging the dongle into another USB port
I'm not sure if these will make any difference at this point, but they can't hurt.
Good luck!
Good luck!
Highest Regards,
Alan T. Hendry, RA
Alan T. Hendry, RA
tried them all before. I swear W7/64 is possessed. I have had NOTHING but trouble with it. I bought X3 because my new system didn't have onboard parallel ports for v.11's dongle and W7 refused to accept ANY card. I'm just hoping that I don't HAVE TO make any changes on stuff I have out right now.
Is there any possibility that you're logged on to Windows with an account other than the administrator?
Try manually removing and then reinstalling the drivers for the hardware key.
Disconnect the key from the computer. Open the Windows Control Panel and select "Uninstall a program." Pick the "Hardlock device drivers" and click "Uninstall." On the first page, make sure to pick the "Custom" removal option. Click on "Select All" and then "Next" each time those buttons are shown, until the process is complete. When you have finished uninstalling the drivers, restart Windows.
Next, go to https://www.datacad.com/update/update_hardlock.htm and click "Download Hardlock Device Drivers (4.88MB)" in the middle of the page. Save the installation file into a folder on your hard drive, such as My Documents, and then double click on it to install.
When that is finished, use the link below to download a copy of the file "hlvdd.dll."
ftp://dcadpub:DataCAD1@ftp.datacad.com/ ... /hlvdd.dll
Save the "hlvdd.dll" file into the C:\Windows\SysWOW64\ folder. Windows may prevent you from saving directly to that location. If that happens, save it to a temporary folder first, such as C:\Temp\ and then copy and paste it into C:\Windows\SysWOW64\.
You may now connect the hardware key to the computer. Windows will display a message indicating that it has found new hardware and will install the drivers. When it says that the hardware is ready to use, shut down and restart the computer once again. When it is finished,
you should be able to run DataCAD.
Please let me know whether or not this solves the problem.
Mark Toce
DATACAD LLC
DATACAD LLC
Actually ended up having to reformat the hard drive yet again. The problem it seems is my backup program (Acronis True Image 2011) which seems to prevent windows from being modified. I kept the hard lock in while installing W7 again and it automatically picked it up and brought in an update and installed it. Once I got Datacad reloaded it worked. So much for Acronis' claims to be "Windows 7 Ready". Now to get Office and everything else reloaded. Been a REAL fun week.
"Life isn't about dawdling to the grave, arriving safely in an attractive, wrinkle free body, but rather an adventure that ends skidding in sideways, champagne in one hand, strawberries in the other, totally worn out, screaming 'yeehaaa, what a ride!"
WELL a final update on this note. I kept having problems and it turns out that my ASUS M4A785-M Mobo was BAD. I picked up a nice MSI board from Newegg and the thing runs like a charm with NO glitches whatsoever.
Thank you Mark, Your solution also works for Windows 10, Datacad 12. Why aren't these full instructions posted to the dcad support page?
11 years experience with DataCAD and Residential Architecture
Users browsing this forum: Majestic-12 [Bot] and 71 guests
