From a post I made to the Debugging team. Might help you guys avoid some problems for now till we figure this one out.
From a post I found while looking for the error below:
Neil Blanchard wrote:Hello,
I just got an error when I tried to Save All -- it said it could not save, and prompted me to save it locally. I think this might have been caused by Second Copy 2000, which was running a backup in the background. It runs on my computer, though the files that are backed up are on Larry's computer.
This has happened to me before, and it is not too bad -- if I do the Save All a second time, it works fine. It just seems like a case of bad timing -- is there anything that DataCAD can do to avoid it?
I also just received a an error warning: "Attention! - Recovery file present. 4049 was not closed properly, Datacad will now recover the most recent version of this file" I checked my recovery and temp folder and had no bad files. I went and checked the computer of my co-worker, and she had had the file open all day, but no recovery files to be found. She had left it open for quite a while when I had tried to open it. I then checked the u$r file and it showed that I was the user, not here. I had already allowed it to recover the file, so it did disassociate her from the file, which caused the save as issue. She also said she was getting the save as error a lot today while in a different file she had open all day. It seems to be related to multiple auto-saves with no user intervention between them, and that's causing the u$r file to loose their status somehow and then the new user taking control of the u$r file. I think I can test this out tomorrow night by setting the autosave time down, open the file on the first system, allow it to sit there until it does multiple auto-saves then try to open the the file and see what happens. I try to remember to set this up.
