Under Construction
Related Links
A tale of two CADs or Josh's Autocad Affliction
Josh's Autocad Questions
Josh's Autocad Wishlist
Josh's Autocad Comments
Comments still to come....
Messy Notes
comments
- distance input
- little display glitches - just about as many relative to the number of features and hardware driven display
- overlapping lines at a distance, ghosting cursors
- can't change layer, color, linetype while creating entities
- pline edit - inserting points having to use next for location
- each layer doesn't seem to remember it's last linetype, color and spacing. global by layer only?
- can't undo without undoing intelipan? works ok for a single command if your going to repat the same command but personally i don't use it this way. i usually undo to do a different command or to undo several steps.
- quick keys customized would probably work as good but not $$$$ better
- $ is cost of file conversion, amount of conversion issues between versions same if not more than the effort between datacad to autocad, even when just between back to back versions.
- high end external rendering package still extra req. but built in rendering supports higher polygons count a lot better.
- shaded textured views would be cool now with new 3d cursor system getting closer
- a better brake?
- get x/y better than implied because you can pan around a drawing rather than dashed line implied which is lost quickly
- fillet only runs once per command, lame
- if you start a selection in one screen but intelipan to where the start point of the selection is off the screen your selection is cut from the edge of the screen. must be a setting.
- to highlight xref, open layer manager, select xref, then apply layer colors. but your actually changing the layers color, with no way to return to original state?
- xrefs add there own layers to main drawing by adding file name prefix. gives direct access to turn on/off, freez/thaw, lock/unlock, but not color change?
- can show only layer for xrefs via layer manager.
- first time draw slow like ???
- stretch and other? commands one time only
- can't undo, copy to clipboard and then redo.
- undo undoes everything, including previous distances
- xrefs only can have one instance in a drawing so if you insert an xref into a drawing which has a nested xref first as an overlay, and then insert a direct xref of the file which is nested in the first xref, you cannot attach your 2nd direct xref because it must obey the parent xrefs overlay settings, can cause a big mess with trailing xrefs.
- no self xrefs!
- when using selection box and do intelipan, goes wonky sometimes.
- having xref layer management in the ref manager is better imho vs in layer manager
- pro or con? moving a pline vertex over another vertex merges to one point. maybe a toggle in pline edit?
- change match properties, undo undoes all changes at once vs each selection.
- moving dim text has no display, just grip
